0/40W Mobil 1 ?
Just what IS the right weight synthetic to run in the Boxster ?
I have been running 5/40W Mobil 1 , and find that it bleeds off the timing chain tensioners over time when parked. Want to switch to 10/40W Mobil 1 - but they seem to have discontinued this and other 40W blends other than 0/40W.
Many Porsche shops recommend 15/50W Synthetic.
Porsche USA recommends 0/40W Mobil 1 !! Why in the world would they suggest such a light blend ??
Any thoughts on this subject ?
JA
0-40 offers more efficiency and HP compared to heavier oil. 40 is heavy enough when engine is hot. i'd consider going to 15-50 for a turbo or SC car but not necessary for NA. Your 5-40 isn't that much thicker than 0-40 when temp is warm or hot.
Thanks for the Input ! But again , my objective is to eliminate the timing chain tensioner bleed down after parked for long periods. ( hate that rattling for a split second )
Edited by jvaski
The rattle is from the hydraulic lifters not the timing chains.
Porsche's "approved" list includes 0W-40 and 5W-40 all synthetic oils
Is this normal for the hydraulic lifters to be rattling on cold start after parked for a while ?
Is there a way to cold crank the engine without firing it to get oil pressure up ?
Cold - yes Warm - no.
There is a TSB for more of a screeching noise on during warmup (on 987's only). If you are getting this screeching noise then you should take it to your dealer and tell them you have the problem described in TSB 1/06 1726 Screeching Noise From the Engine During Warm-up -- dated Feb 27, 2006.
