ECU removal / installation howto
Just been wondering if there are any special notes regarding ECU removal and/or re-installation on the 987. I'm planning to send the ECU for some reprogramming but was not sure if it can be done without any hassle (I mean disconnect everything, remove ECU, then when it comes back just reconnect everything and it works fine) or it may activate the anti-theft electronics?! Should I disconnect the battery before ECU removal? Any help would be appreciated...
Yes.
As long as they don't change other programming (i.e. OBC, cruise, country codes, etc.) you should not have a problem. BTW... Porsche will be able to tell the DME has been tampered with - so they could use that against you in any (related) warranty issues.
