Door Window Height
I thought I read somewhere that you can set the final height of the door window after say a new regulator, I am getting a squek and rattle close to the passenger mirror in the final up position it goes when the window is lowered a couple of mm, without removing the trim can I re-set a new final position? I'm naturally terrified going near airbags!
I have searched but recal reading after a new regulator is installed that you can set the final position by fully upping the window somehow, maybe I could insert some card into the upper roof groove and lower the window final position by 1 mm to eradicate the noise, lub into the window area only made things worse.
http://www.renntech.org/forums/index.php?s...ost&p=11090
