Caliper Fading?
The Calipers on my 987 Boxster seems to be fading rather quickly and it only has 26k miles on the odometer. Is this normal?
Can I get the dealship to replace them or will they consider it wear and tear? If so, is powdercoating safe and where's the best place to do it in NYC?
If the car is still in warranty, then Porsche will replace them. I had 3 calipers replaced because of clear coat delamination on my 996.
You will probably need to be perseverant with your dealer to get done, but paint defects like that are covered in your warranty. The issue is that the paint is for corrosion control as well as aesthetics. The braking and thus safety capabilities of these calipers are compromised because of the increased risk of corrosion due to the failure of the paint.
Not so sure I agree on the corrosion issue as in reality this is purely for looks. I agree try and get them to repaint it but if not it is not that difficult to repaint yourself.
Best of Luck!
What did you say or cite for them to replace or repaint them? I want to go prepare, at this point I know nothing about claiming warranty issues with Porsche...
They replaced the calipers.
The work order description was:
"Brake Concern
Customer states paint delaminating from fright front brake caliper.
Found caliper faulty
Replaced brake caliper to correct -Warranty"
