Part number help
I'm looking for two part numbers for my '03 C2 Cab.
1. I need to replace the Velcro strips that join the inside headliner pieces on both sides in the back. Local dealer never got back to me and I can't find them. I did come across something at Home Depot, but the instructions said they were not to be used on fabric.
2. I'd like to replace the wheel liner (front drivers' side), but it doesn't quite look like any of the drawings I found on dcAuto's website. Here's a pic:
Could it be 996.504.123.03? I guess I should remove it and check the number on the back of it, assuming it's numbered!
tom
2. Left front wheel liner 996.504.203.06. You will also likely want to buy a few spare plastic rivets since they sometime break in removal - 999.507.497.40 Plastic Rivet
1. Here is the parts list for the roof liner (for the convertible top).
Perhaps you can tell what you need from it.
my03_roofliner.pdf
Thanks Loren. I envy your technical library!
What's the best way to remove the plastic rivets? It looks like an upholstery trim tool might work well.
Here's a picture of what I'm referring to for the roof liner:
The 4 sided piece in the middle of the photo has the velcro strips. Do you think that that is item 6 in the pdf you attached?
Thanks again.
tom
