Block heater # for Cayenne V6
I have had engine block heaters on my Ford Explorers with excellant results. Nice to go out to your truck, on the driveway, turn the key, and get immediate heat on a -15 degree day! They usually insert into a "freeze plug" on the block. Sounds like Porsche makes it much more difficult.
I assumed it would just be a frost plug too... isn't that what is on the VW VR6?
weird....
If you mean option I7VE auxiliary heater with timer - I think it is quite a chore to install.
I think you are looking at electrical harnesses and lots of coolant hoses and re-routing.
The parts would also depend on your VIN number.
Here is an example parts listing...
aux_heater.pdf
No... thats for a heater in the back of the car....
It is likely a small fitting that will bolt to the side of the block or into a frost plug and will have a 110V ac power cord. There shouldn't be any coolant hose changes (thats a potential failaure area you don't want in the deep cold)
TC
I did not see one in the parts list - do you know the option code for this?
hhmmm no... do you know if there is an option cross-reference online somewhere ??
The MY05 Cayenne order guide (with all the available options) is here.
Loren... That was quick !! Thank you !!!!!!!!! I'll take a look and see if I can spot the option :D
