How do you identify engines?
We picked up a water-cooled Porsche engine yesterday that will probably be taken apart and sold in pieces (large pieces!). We're an Audi Volkswagen place and know nothing about Porsche. How would I go about identifying the engine? Its basically a long-block with an intake manifold.
Numbers I found so far:
Case:
996 101 149
996 101 142
Heads:
996 104 137
Valve Cover:
Vario Cam F1
Number engraved on case:
23852197 2228*
Any help is appreciated,
Dan
Sorry, all of your part numbers are missing the last two digits.
Since it says VariCam and not VarioCam Plus that would imply that it is a 3.4 liter engine (MY99-MY01).
Curiously, none of those numbers are listed in the 986 and 996 USA Genuine Parts Catalogues on-line at Porsche Technical Service Information.
Aaah, now that you got me going in the right direction I noticed a 3,2 at the end of the numbers on the heads. Some photos that I found on the internet of other Porsche engines does make this one look like a Boxster. 3.2L Boxter engine? I had one of the guys take the valve covers off the look at the cams (weird covers! including the cam journals) and they looked good, along with the journals. I don't have any history on this engine but it did turn over by hand and make compression in each cylinder as it went around.
Any guess as to what its worth? I'm not interested in squeaking out top dollar, just want to move it and pay for our time.
Dan
Dan
The Motor Mount is Boxster and the oil cooler looks like a 3.2. It looks like a 3.2 Boxster too me.
Dan
That looks to be it: 3.2L Boxster. I guess the part number is for the head casting itself. The catalogue lists only complete head assemblies.
Look on the flat plate next to the oil sump, there will be an engine type and serial number stamped there.
it will start with M96/......, this will tell you the year and engine type. The numbers you posted above are casting numbers not part numbers.
Based upon the coolant outlet configuration, the motor mount, the taller oil cooler and the fact there are no intermediate aluminum intake risers it is a 3.2L Boxster engine.
Todd
Edited by tholyoak
