Very strange coolant leak
MY99 996 Coupe. Recently replaced the water pump, so i also replaced 3 gallons of coolant with Prestone. Since then I have noticed a strange coolant leak coming from the front, high driver-side of the motor, looks like a plug in the block or head near the oil separator.
The coolant that escapes forms in my garage only, but is like a jelly until I wash it away with water. I also discovered an electrical connector hanging down the backside nearby, unplugged. After reviewing diagrams, all I can figure out is that it might be a pulse sender since it is the same general area (986.606.112.02). What the heck is a pulse sender?? Wrench thinks the leak is originating from the oil separator, but why would coolant be seeping as a jelly-like substance instead of oil?
Should I flush my system and replace it with OE Porsche coolant? Does OE Porsche coolant have a sealant in it that the Prestone thinned out? I lost only about 4 ounces of coolant in the past two months, but I am concerned about it getting worse...especially if I take it to the track.
Edited by deanslist.us
No oil leaks, just coolant.
I read about the jelly thing on another thread and have since inquired a two gallon order of OE Porsche coolant from Sunset Imports. Is there a special fluid I should use to break that down and flush it out? I know regular water works when diluting it on my garage floor, maybe I can apply the same principal in the system once I get the new coolant. Off-hand, does anyone know if the OE Porsche coolant has to be diluted as well with two parts water for every one part coolant, or do I need to order four gallons?
It depends on what Prestone fluid you used. They make one that is fully compatabe with the Porsche coolant. I use PEAK Lifetime 50/50 rather than the premium priced Porsche packaged fluid. http://www.peakantifreeze.com/peak_global_lifetime_5050.html I believe the Porsche coolant is not diluted and needs to be mixed with distilled water.
If you added the wrong kind of coolant, I suggest you flush the system competely. The system holds around 6 gallons of fluid.
Edited by 1999Porsche911
