Wheel paint touch-up
I have a very small 0.25 inch square chip on my wheel. I have purchased Wurth wheel lacquer, but was wondering if I should attempt mask and spray this area, or spray some paint into a cup and use a touch up brush. Has anybody done any minor wheel touch-up and could recommend a process?
I know there is an article in this forum, but that's more about using bondo on a rim scrape.
thanks,
Simon
I guess this may be a silly question, but will lacquer thinner affect the original paint at all, or is it safe to use?
Simon
Yes, lacquer will damage paint so be careful using it. It will take off the clear coat for sure and likely the base color if you rub.
