2007 987 water temp gauge not working
:huh: Hi all, I have purchased an 2007 Boxster for resale. The right rear suspension was damaged, no frame damage, engine damage etc. The left front radiator was damaged by the towing company so i had to replace the radiator. Now I see the light in the area where the coolan temperature is flashing and it does not appear that the temp gauge moves along with a message stating faulty sensor/gauge or something like that. We filled the radiator appropriately but the guage and message is still there. Could it be a fuse? The car is still under warrantee but if something is shown to be part of the accident then it wont be covered. Anything i can check?
Fred
Ah... 987 Warning light For Coolant Temperature Gauge Activated
Have your local dealer perform the action in TSB 2/06 1912 Warning light For Coolant Temperature Gauge Activated -- dated April 18, 2006.
My car is an '04 986S (anniv. model) and today a red light started flashing in the temp gauge along with a "failure indicator" message. Does this TSB also apply to the 986 models? FYI: The gauge isn't reading at all.
Thanks in advance.
Thanks in advance.
No, the TSB is for the MY2005 production run of 987 cars only.
You should check for leaks or a bad sensor.
