2.7 engine replacement in a 2002 - What engine years will work?
Guys,
If I wanted to replace my 2.7 engine in my 2002, what engine model years are a direct swap? Could I use a 2.7 that came out of a 2005 987 without having to make a bunch of changes? The goal is to remove the old motor and simply bolt/plug in the new one.
Thanks for any help you can provide,
-Colin
If you want to just bolt in without problems, search for the same MY. Younger types could be different. ( DME - engine design - wiring - connections )
