I have a 2000 Boxster 5 speed in Richmond VA. Had a problem with e-brake microswitch for the top, fixed it. I DID take the seat out with the keys in the ignition so i could trouble shoot microswitches and get up under the dash. The light has been on for a couple of days. OK so where did I screw up guys? And how do i fix it? Thanks for help in advance.
Shawn
Shawn
Shawn:
For future reference, it is possible to take the driver's seat out without disconnecting the main electrical connector under the seat. The wires are long enough to (carefully) lift the seat out and place it on the ground besides the car.
Shawn
Shawn:
Or just invest in Durametrics and reset your light :)
It is a good tool and you can also monitor various functions to see how your engine behaves and how the sensors react, etc.
