Wheel lug bolt grease
I recently installed spacers, and when installing the new longer lug bolts, put a small amount of grease on the areas of the bolts where the user manual specified Optimoly TA. I just used regular high temp grease.
I've subsequently read that you should not use grease because it can lead to over torqued bolts. So, what should I do?
thanks,
Simon
Yes, the service manual actually says:
"Thinly grease thread, shank and under head (between screw head bearing surface and spherical cap ring) of the wheel bolts with Optimoly TA (aluminium paste). Do not grease bearing surface of the spherical cap facing the wheel. If heavily contaminated, clean bolts first with a lint-free cloth."
Optimoly TA -- US MSRP $27.11 for 100 grams!
