Yes, they update the program almost monthly so I still use and recommend it. It does all the basic stuff most of us need. A PST2 or the new PIWIS system from Porsche can do much much more (and cost over $4000!) - but some procedures require network communication to Porsche for authorization. There are no aftermarket tools that can do what a PST2 does today.
Normal 30K maintenance - Well you will need filters and the link at the top (Porsche Parts at Dealer Cost) has a kit with oil, air, and pollen filter for $88. Plus you will need oil - about $45. Depending on the year of your car you need to change the spark plugs - about $60. And, if you haven't changed your brake fluid for 2 years (or more) you will want to change that too - about $10.
So, if you DIY, under $200 doing all of the above.
I just bought mine.  It is a 2000 C2 with 11k miles.  I would like to do most of the work on my own.  Especially, oil change, filter change.  Not quite sure on the plugs?? Thanks for the quick response.
Can the OBD- reset fault codes??
On a MY2000 somewhere between 30-36K you will want to change the spark plugs to the newer heat range and if they are not already the 4-prong plugs. It is not that hard with the right tools - the short swivel head rachet is the key (and a little patience).
The OBD-2 software I spoke can reset DME fault codes and several other system(s) codes.
Yes, Porsche is ISO protocol as are most European cars, Asian cars and Chrysler (American) cars.
I had a look at the site and cable package you show above - it is hard to tell if it includes the software. They did not have any software screenshots that I could find. I guess it comes down to knowing people that have used the product and validation that it works.
Ah... looks like the German version of the same cable/software. Price looks good too!
If the cable is properly made then there is little or no risk of damaging the DME. I have probably plugged mine in several hundred times.
