For those that have been following my trials and tribulations....it appears my warranty company is covering the cost for a new engine. I will have final confirmation tomorrow hopefully.
My question is, while the engine is out, is there anything else I should repleace proactively? The car has 49K miles and is on the original clutch, so if I save some labor there it may be worth it. Any other thoughts?
With a new motor you want a new cluctch and throw-out
bearing. Easy install when the motor
is out. You may want new motor mounts also. Last I would
look at the radiator hoses.
Paul
maybe you should replace your coolant tank if its old and yellowish... its alot easier to change when the engine is not there...
Yes, I would do the clutch while the engine is out. Have them check the RMS too. May want to do you 60K early too.
Assuming that your not planning on using the spark plugs and oil out of your old engine, the only part of the 60k service you wouldn't be doing is changing the air filter and visual inspections.
