Just noticed that my front hood doesn't close very well in line with the bumper (when closed). Just wondering whether there is a possiblity to adjust the vertical hight at the bumper side (not the window side)?
Thanks, frank
To some degree yes. Look for the two rubber bump stops on the inside front edges of the hood.
It is also possible that your front bumper is not proper aligned.
When properly aligned the front bumper should be even to just slightly higher than the front hood (otherwise you will have wind noise).
