Oil Quantity Indicator
OK .... Yes, I did a search first.
Changed my oil last week, and all was normal immediately following: dipstick showed just below max, and dash indicator showed one tick down from top.
2 days later, dash indicator shows absolutely empty, and flashes on and off for a while after starting the car. Dipstick still shows between the marks, and pressure / temps are normal.
Any suggestions on where to go from here?
Check the oil level sender electrical connection on the engine.
If it is okay then you likely need a new oil level sender.
Thanks, Loren. Can you direct me to the sensor?
