04 Cayenne Turbo 22k Miles Brake Pads Warning
Mileage is not the point, the condition of the rotor is determining.
How do I determine the condition of the rotors? I'm not experienced with this kind of things. I assume the dealer would suggest to replace them as well regardless of the condition.
Anyone? How do I tell if the rotors need replacing? I've been told that the rotors usually last twice as long as pads?
http://www.renntech.org/forums/index.php?s...ost&p=64125
Does that apply to Cayenne Turbo as well? I thought they have bigger rotors than the S?
Yes, the Turbo and S brake wear limits are the same - UNLESS you have the optional 19" rotors.
