Just a question, is it recommended (or not) to place the clear bra material on the new bi-xenon headlights?
Go for it. It protects the "glass" from pitting over time. AFAIK, it wouldn't affect the bi-x performance.
Paintshield offer a kit for the boxster pre cut and ready to go. It uses a thicker film for the headlights and front indicators as these are more prone to deeper chips as a result of the plastic being softer than metal.
Well FYI I spoke with my clear bra guy about doing this myself and he said the clear bra yellows real bad on the Bi-Xenon lights but I did the lower running lights!
I have XPEL and so far it does not yellow at all.
Xpel is the best I have seen. Better than 3m at least. There shouldn't be a problem with the headlights, and it is reversible so you can always change it out if it yellows :)
Steven
Yeh I also use Xpel, they use the 3m film and laser cut it. The headlight film is thicker than the normal body film. It will yellow over 5 years, but it doesn't cost that much and you can do it yourself so if you want you can change if after a few years. i got mine from autosupermart.com the part number should be H2502A for a 987 boxster
