01 Cab with clam shell stuck in closed position
Actually heres an update on whats going on...
when i use the button on the center console to try and lift the top, I hear a light click sound from under the top but no movement what so ever.
when i try and turn the manual allen bolt to lift the top, only the passenger side of the clam shell will lift, but not the drivers side... it only goes up about 1/4 of an inch then i cant turn the allen bolt any further.
OK figured it out but i have a new issue now...
problem was that the tiny push rod that pulls the clam shell lock/latch's clip had uncliped it self to the clam shell was stuck in lock position.
New problem now is that now after i reattached the rod to the lock latch... the clam shell doesnt move at all just like before, I have to manually lift the clam shell in order to get the rag top up. when i get the clam shell all the way back, i can use the button on the console to get the top to close and open... problem is that the clam shell wont shut afterwords... how do i get it to start working again...
I can hear a sound below the clam shell like it wants to try and open but nothing happens.
