Is this for a Boxster or Carrera - you posted this in Carrera but your profile says Boxster?
I can move this if it is in the wrong place.
Its for a C4.
You can fit a PSE without the switch. The default position for the valve is loud. However, if you don't want to fit the switch, why not buy an aftermarket exhaust, as it will be a lot cheaper than a PSE.
Thanks Loren. I notice the TSB says 750 Time Units fo rthe full install. Is a time unit one minute, as it seems to take a massive amount of time if it is?
100 Time Units = 1 hour
So 750 TU would be 7 hours 30 minutes.
I can put the whole PSE muffler set in a car (w/o electronics) in less than 1 hour.
