NO HEAT
Izzy
This is a new one, the AC works great in the car, nice cold air. But no matter what temp setting I set the system at, it is always cold, no hot air. Any suggestions? I did check the fuse, it is good. Next thing I was going to check is the temp sensors, if I can find them. Suggestions appreciated
I tell you what, last week at VIR, it was COLD in the morning and I was freezing. Warmed up later, but I did miss the heater. I am going back late November, will need some heat....
Rixter, it was the heater valve, it came off the plastic bayonet bracket it sits on. Put it back on and problem solved this morning. Thanks!
