Problem with Durametric
I have a 1999 996 Cab
I'm using the Durametric software to try to clear an airbag light, but I can't connect to any module.
Software says: Module Failed to Initialize.
This is the same for all the modules:
Airbag
ABS
Seat Memory
etc...
I can only see ECU info.
What could be the problem? Is it unlikely all these modules are bad at the same time.
I contacted Durametric.
They're saying it is either a problem with the durametric cable (which i just returned so they can check it) or one of the modules on K2 (airbag, seats, AC..) is causing a problem.
Anyone had the same issue?
Fred
  • 3 months later...
Fred
How did things turn out on this? Was the cable the problem?
