Changing battery in 2004 S-is it a DIY job?
Hi folks,
starting to have a problem with a dead battery. every 3rd or 4th start....nothing....jump it and it's fine. before I start looking deeper, I figured it's a 5 year old vehicle with 60k miles, so start with something easy like replacing the battery....wow....I find out there is an auxiliary battery in the trunk, and under the section about replacing the battery it talks about having a pro do it...chance of voltage issues, etc.
now, I know with some things this is usually baloney, and just an excuse for the dealer to rip you with a $400 battery. But I saw no such verbiage in the manual when replacing the battery in my wife's 2002 Boxster S.
so, is changing the battery a DIY?
thanks very much...
There is no battery where you indicate
Primary battery is under drivers seat, if fitted, a secondary battery is under the sub woofer in the trunk (03/ early 04 only )
I know of only one battery, the one up front just ahead of the windshield...
Also, isn't there a caveat about the radio and it's code?
MY04 Cayenne.
Two batteries if no sound system and radio is MOST so no code.
MY04 Cayenne.
Sorry, my bad, I saw the 2004-S and from his description of the 'wife's Boxster-S' and assumed we were talking about it not the Cayenne... I'll go back to my dinner now. ;)
thanks folks,
final question. what about these "micro encapsulated seat bolts"? this is a new one on me. You must replace the seat retaining bolts on the driver's side when replacing the battery, according to the manual......really? C'mon.....
plus, I can't find anywhere in the specifications or in the battery section of the manual where it talks about cold cranking amps or the amp hour rating...anyone know?
OH, and one other question. the battery I got(Autocraft) does NOT have a venting outlet for the hose to hook to. Is that a big deal?
Edited by BoxyLady
thanks Loren,
so can you help me out with the amp hours? it's not listed on the battery at all(the new one). only the cold cranking amps at 32 degrees and at 0 degrees. I have found several formulas for deriving the amp hour rating, but there seem to be a lot of variables in getting the number: what end of cell voltage I am using, how long the dischrage period is, etc. seems very complicated for a car battery. For years all I ever had to worry about was how many CCA's does the vehicle require for cranking at a certain temp. and I was done!
also, should I be concerned about there not being a vent outlet on the new battery to reattach the venting hose to?
I'm starting to wonder if I need to take it to the Porsche dealer and pay them $400 for a battery replacement..... :-)
Battery venting is extreamly important. Without outside venting the fumes will attack the battery box with acid fumes and corrode them. Some afternarket batterys offer an adapter to fit on battery to go to vent hose.
The first time replacing the battery was a torture session. After having the right tool, aka "#10 triple square socket", it was a breeze. Carquest has most parts for the Cayenne, including the updated Bosch coils, that gave some of us fits. Their direct replacement battery (breather tube port style)part # is 93-72.
