my new 2001 boxster
Hello to everyone on this forum...
I just got my 2001 cobalt blue 2.7 tiptronic Boxster that I ordered from the US.
The car has been in sea for 1 month, so I already predicted there would be some minor problems.
I will be taking it to a mechanic on Monday, but I thought I'd ask if there were any quick fixes for the following:
1) The rear spoiler doesn't go down (it was up when I got it).
2) The radio (6CD box) will not start, nothing is displayed on the LCD.
3) The remote lock key does not work: when I push on the lock/unlock in the key the red led is illuminated, but the car doesn't open/lock.
4) The turn signal blinker only works when I push it downwards (left blinker), it doesn't stay up when I push it upwards (right blinker).
5) Does anyone know whether I can switch the speedometer (the digital display) from MPH to km/h? Also the temperature from Fahrenheit to Celsius?
I will be uploading some pics soon.
Thanks a lot everyone!
Congrats on the Boxster!
Now, I'll try my hand at some answers:
#1 Spoiler: got me on that one maybe a fuse blew out?
#2 Again with the fuse theory.
#3 If the key un-locks the car in a normal fashion by using the key, either the battery is low or the key fob is bad.
#4 Blinker switch on stalk is damaged
#5 If you pull the on-board computer lever towards you (a couple of times?) it will let you scroll the options for the display.
Thank you Beelzy!
The key unlocks the car normally. Isn't it possible that the problem is with the receiver and not with the key fob?
Also I should have mentioned that when it came, the panel near the driver's seat was unscrewed (the cables/fuses were visible).
Thanks again
Salt air is about as corrosive as you can get above water. It can really reek havoc on electrical connections.
You might want to check all the related wire connections. pull connectors off and on a few times. The same for related fuses. They don’t need to look corroded to be “open”. Moving them in and out of there sockets kinda’ scratches the connections clean.
You could also have corroded contacts in the related relays. These can be cleaned to by popping the caps and running some fine sandpaper between the contacts. Then blow them out (this is sort of a a no-no but it always works for me*).
Regards, PK
*Put it this way, in 9 years I never bought a relay and never fixed one twice. I've had more than my share of electrical problems
Edited by pk2
Updates:
Spoiler is working.
I have checked the fuses, specifically the D8 one which is supposed to be responsible for the radio, but it looks fine. I tried cleaning them like PK suggested, but the radio still won't start.
Today I took the car to get my rear wheel changed, but to my surpise there was an anti theft lock on the wheels and I couldn't find any key inside the car.
I really appreciate your replies everyone...
