I had the 02 sensor replaced and the ECU is still throwing out this code:
P0134 - 02 sensor - interruption of signal
Would this be due to the MAF being unplugged at present? That's what i am thinking...
P0134 Oxygen Sensor Ahead of TWC, Bank 1 – Interruption of Signal
Potential causes:
– Wiring harness
– Oxygen sensor
– DME control module
Did you check the wiring harness?
Was the right sensor changed?
Potential causes:
– Wiring harness
– Oxygen sensor
Yes, right sensor was changed...lost code P1126 (if I remember code right?!)...P0134 only code i get...well, will either be wiring harness (nothing dodgy apparent) or DME then..sigh...any money its the DME!
Never straight forward this...any checks I can do that do not require much messing about?
Edited by Elliottc26
Potential causes:
– Wiring harness
– Oxygen sensor
Mouse chewed the wire harness?? It happens.
