Hi all,
I have a 2003 996 C2 UK spec car.
I have had the car for 2 years and have always had problems with bump steer/poor steering handling. It got progressively worse and worse and so recently I took it into a good Porsche specialist for them to take a look. They diagnosed it was a problem with the tyres and so I got them to put on 4 new Pirelli PZero Rossos. The geometry was done and all wheels were balanced.
The car drove fantastically for about 4 weeks then the problems started again. I am getting some bump steer and the steering feels very light again – like not all of the tyre is making contact with the road.
It seems like the geometry has been pushed out of alignment but I don’t drive the car hard and I can’t think of any reason why the geometry is out (i.e. I haven’t hit a bump or kerb at high speed) I do drive over speed bumps but not at excessive speeds.
I can take it back in to get the geometry re-done but at £250+ per time it is expensive if I have to do this every 4 weeks!
Does anyone know of the root cause of the geometry keep being pushed out of alignment? Are there any other components that I should replace to keep the geometry aligned?
Have them check the upper strut mounts for wear or for being loose.
Under the car have them check the torque on the front swaybar - these loosen with time too.
