Has anyone replaced a front wheel bearing on a boxster or 996? Will I need special tools or can I make them? It looks like the strut insert will have to come out of the bearing carrier and then press it out through the outside. Thanks for any pointers. J. Mrva :beer:
You also need a press and a torque wrench good to 348 ft-lbs (to reinstall the nut on the axle). The hard part is getting the old bearing out. Pressing in the new one is easy if you freeze the bearing and heat the wheel carrier. When I did it we took the strut and wheel carrier off of the car.
