Hello all..
I've read as much as possible in the archives about DIY Tip service. Bentley manual says 3.5 litres for a fluid and filter
change. I'd like to change as much of the fluid as possible. Loren commented that it usually takes 7 litres. Can I get 7 litres out of my transmission
if I'm doing it myself? Or does this require a machine like the ones in the Fast Lube places? BTW, 2000S Tip.
Any thoughts? Loren?
Cheers
Mike
Hello all..
Cheers
Mike
Izzy said he used 7 quarts (Tiptronic Transmission Service).
It is actually 9 liters for a complete drain and rebuild.
A normal change is 3.5 liters according to the Porsche service manual.
Thanks...I re-read that article and it's unclear how he got 7 quarts out of the trans.
If it's just from draining the pan and replacing the filter...I will be happy!!!
Cheers
