I have a 99 boxster got the 1123 and 1125 codes, from the research i figured i needed a new maf. i replaced the maf and got the same codes after about 3 drive cycles. i really need help i dont know what else to check next. the bellows looked good i checked it today and also have looked for anything obvious
Edited by aerogianni
:welcome:
P1123 Oxygen Sensing Adaptation Area 1 (Cylinders 1 - 3) - Lean Threshold
P1125 Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Lean Threshold
This says that the DME thinks your mixture is too rich - and can make it lean enough.
Potential causes are:
- Fuel pressure too high.
- Fuel injector leaking.
- EVAP canister purge valve open.
Make sure the MAF is functioning properly by reading the air flow at idle and at 2500 RPM no load (you will need Durametric software, a PST2 or PIWIS tester to do this).
Scan for more codes - It could be a stuck EVAP purge valve.
:welcome:
my scanners will not give me much information, i really doubt an injector problem on both banks, how could i determine a stuck evap valve
:welcome:
Check for additional error codes. If you have evap issues you should get codes.
