air conditioner control module
I have just replaced the a/c module on my 2004 cayenne. the replacement was simple, but now i have a flashing display for about 10 seconds after the engine is started and the controller does not appear to be functioning correctly. The dealer says the master computer needs to be reset. can i do this myself?
Probably not - you will need a PIWIS tester.
So, find a shop or dealer with one.
Thanks for the information. Is there an aftermaket tester available?
You can check with the folks at Durametric - but I do not think their software does this yet.
I went to the dealer, got the computer fault codes reset and everything works except the side vents. I have seen a couple of posts about actuators. Could this be another problem with my system?
