I have a MY 2000 Boxster S. I took it for a short drive and noticed that there was no oil that is registering on the Engine Oil Level Guage. I checked the oil manually using the dip stick and all is well, so i continued my drive home. Does anyone have any suggestions on what to check, loose connection, etc.? I did add a few ounces to bring the oil level up to max on the physical dip stick but still do not receive an oil level on the display screen.
Thanks in advance for any advice.
Andrew
Is this the same as an oil sender? I am doing several searches found this reference. Thanks Again. Andrew
Item 26
996.606.150.00 oil level sender -- US MSRP $53.30
Try the folks at Sunset Imports (Porsche Parts at Dealer Cost) for better pricing.
