I have a 01 Boxster S that has a strange rear spolier issue. The rear spoiler raises and lowers as it should automatically and manually, however on startup the light is on untill the car is moved. Once the car registers MPH the light disappears without issue. Is this normal? Any sensors or micro switches to check. Any help would be appreciated.
Thank You,
Andrew
What you describe is normal operation for the warning light as outlined in my user manual for a 2000S
I don't understand the logic but it is normal.
Thank You,
Andrew
Normal.
Thank You,
Andrew
Normal.
Had the same thing happen to me on a '99 996 when driving away from a dealership. They said to drive it a few feet and the light would go off. So it did;... seems normal.
