ECU Part #
Strange, I understand what you are saying Loren but then I have to ask, the ECU is programmed the same for a Turbo or Turbo S, I would have to say no. Or is this just the part (ecu) and then a dealer/porcshe would have to program it to the model it will be used in/for.
If so I guess that is what they are requesting...?
Edited by madburg
Ok, so that all makes sense then. I am at a bit of a lose as to what they want (they state ECU #).
The Dealer is working on the car still, and they gave me the Serial # and Sfotware # and GIAC said "no" neither of those...
I wonder once i pick up my durametric if that will show the "ecu #" there are referring too?
Very good to know Loren, many thanks. Once my durametric comes in, will I see the IPAS code labeled as such ("IPAS")? This way I make sure I do not hand that over to anyone. I am guessing the software will show the ECU # which I hope is not the IPAS code you meantion and is what they need...?
No, your car's IPAS codes must be obtained from a dealer. They should not charge you for this information - but as I said protect them with your life.
