C4S (Turbo) Brake Pads/Kit for DIY Brake Job
MY02 on C4S (cast iron brakes not PCCB)
Front -
Pads: 996 351 949 12 (1 set)
Damping Plate: 996 351 089 00 (4 needed)
Wear Sensors: 996 612 365 00 (as needed)
Mounting Parts Kit (bolt, spring clip): 996 351 959 11
Rear
Pads: 996 352 949 02 (1 set)
Damping Plate (28 mm): 964 352 096 01 (4 needed)
Damping Plate (30 mm): 964 352 096 00 (4 needed)
Mounting Parts Kit (bolt, spring clip): 996 352 959 11
  • 3 years later...
Front -
Rear
do the p/ns above apply also to MY03 C4S (cast iron) ?
Front -
Rear
Yes, but the part numbers may have been updated (that post is almost 4 years old). Check when you place your order.
