Hi--My 2004 911 Annv. parked in garage - The last 2 days in the morning only it now takes 2 trys to start up .Before it allways started on frist try. Whats happen ??? :huh:
battery would be my guess.
Thanks --But the battery is less than 1 year --Battery sounds strong :(
Unfortunately when you say the battery is 1 year old doesn't mean much (in terms of manufacture). Do you keep it on a maintainer? If not, it would be my first suspect as well.
Just pluged into today -I'll see what happens tomorrow :o
What do you mean by not starting? Turns over but does not fire up?
If so, my first suspect would be gas.
Yes! -Maybe fuel injector ????
No, I don't mean fuel injector I mean bad gas.
Highly unlikely that all 6 injectors would be bad.
Would'nt I feel it when driving ????????
Because once combustion starts the chamber is heated that helps with combustion.
Re-fill the tank and see if it gets better over a week or so.
Will do --Thanks :)
Loren -Good call -Filled up fresh gas diffrent station --Problem solved -Your were correct
Thanks Again
Rick :)
