Anybody have any wiring diagrams for 08/09 cayenne as i am trying to fit a pcm3 unit into my cayenne. The unit has powered up everything seems to work but there is no sound as yet i have not installed a bose amp.Would it be possible to use a non bose amp?
:welcome:
You don't need a wiring diagram - Porsche produced a TSB with the complete installation procedure.
TSBs are available here to view by our Contributing Members.
:welcome:
i have looked for tsb for installing pcm3 into caayenne but could not find it. which number is it?
:welcome:
Hi i'm new here
First at all please don't wondering about my wired english, i'm from Austria and understand allmost everything. but i have problems with gramma and timeforms ...
I own a 2005 Cay S in very good cond. last mont i changed the old center gauge cluster against a brand new turbo cluster.... works fine...
now i got a pcm 3.0 and my next project is to excange the 2.1 to the 3.0
question... how to became a contributing member?
can anyone send me the TSB?
cause i need the conection diagram to build me a pcm 2.1 to 3.0 harness
is it true that the Bose amp must replaced by a09 model cause the MOSTcomunication is different ?
If it is, i also need the conection diagramm of both amps (old and new)
hope some one can help me
regards from Austria
Sascha
  • 2 months later...
Don't think this is exactly what you are looking for, but I have provided a wiring Diagram for 2006 Cayenne Bose Stereo...etc. Thought this may help?
Good luck!
DC
Hi, thank you for the share, it's a very clear wiring diagram. Do you know where can I found the same thing but for the new 2009 Bose amplifier please ?
Thank you.
Good luck!
DC
Thank you.
Hi anubis.
Maybe you can tell me where do you find the TBS for the wiring diagram and the TBS number.
Thanks.
