This is my 55th lap at Nürburgring Nordschleife, definitly no attempt to drive a fast lap, but still a BTG around 8:29.
I have added the names of the bends of the track as I know them.
I'm open for suggestions regarding this..
The sound you hear is a bad "wheel bearing" that desperately needs to be changed.
The car is my track modifed 996 Turbo -01.
Some pictures taken by Jochen on www.frozenspeed.com
Nice line (mostly), smooth and clean driving, congrats! B)
I think you have a very good base to work on. Add some speed (slowly!) and confidence, and you'll soon enjoy some very good laps at the Nordschleife!
EDIT: Btw, what are your mods?
Edited by pierre
Mostly?!?
You can not say like that..and not say the rest.. Where?? :huh: :) :D
Mods:
* FVD stg 3 (540hk/760Nm)
* Europipe Stage 2 Quiet
* Bailey Diverter Valves
* FVD Bilstein PSS9 coilovers
* FVD camber plates for PSS9
* FVD Eibach adjustable sway bars
* Porsche Motorsport 6-piston/350mm brakes
* Pagid Racing Brake Pads - yellow in front/black in rear
* FVD Braided Steel Brake Lines
* Techart 18" rims, 8½" + 12"
* 18" track tires, 235mm + 315mm
* Porsche original shortshift
* GT3 seats - black leather/alcantara
* Porsche Tequipment Safety Roll Bar
* Schroth 6-point belts
* GT3 RS brake cooling ducts
* Cornerweighted
* FVD Sport Clutch Kit with Light Weight Flywheel
* Rolled rear fenders
* Odyssey PC925 lightweight battery
Thanks for posting. I won't comment on your driving, but it would be cool to add gear/speed overlays to the video (if possible).
Cheers,
Sorry, but if you mean that you want to se my speed and gear in the movie I can't fix that.
The movie is just taken with a ordinary bullet cam..nothing fancy..
Regards /Pär
BTW:
Another interesting event I attended on two weeks ago at a Swedish track..
Formula Renault 2,0:
Chassie: Carbon-fibre Monocoque, carbon bodywork
Engine: 2,0L Renault engine with 220hk (related to Clio Renault Sport 2.0 16V)
Acceleration: 0-100km/h på 2,3 sec
Top speed: 270 km/h
Transmission: Sequentially controlled, dog-clutch box with 6 forward gears, changeable ratios, self-locking differential
Tyres: Michelin
Fuel tank : 38 litres
Weight: 490 kg
This was definitely mindblowing and something I hope to do again.
BTW:
Top speed: 270 km/h
Tyres: Michelin
Weight: 490 kg
Please re-read the board Guideline/Rules here - Porsche content only.
Thank you.
Sorry for that!
I guess that the fact that I drove my Porsche to and from the event is no excuse.. :)
I can remove my post if you want?
Regards /Pär
