Click here to Donate
Boxster small oil drip on garage floor
I have a 1997 Boxster and today I noticed some oil on the garage floor. It looks like its dripping from about 8 inches right of the oil filter container when viewed from the rear. I have attached some photos, can someone help me with this one?
I hope its nothing major, the car has only has 30K miles.
Between the engine and transmission joint?
If so it is likely the RMS or IMS -- both very common leaks especially on the older cars.
Transmission will need to come out to repair the seals. Check the clutch while you are there for oil or wear. Could save you money down the road.
