I would like to perform a 90K maintanance on my 2.5L. I still have some miles to go but want to prepare in advanced.
I intend to change:
- Oil
- oil filter
- Fuel filter
- Air filter
- Spark plugs
- Spark plug cables?
Can anyone provide the PN's,brands, or a link to someone's site that has done this?
Edited by scherb
When I started out 5 plus years ago never thought I would see a 90k Boxster.
On local cars we have done the 15, 30, 45, and 60k service. See if you can find out if the 75k service was done.
I will give you a list of parts at the tech session.
Oil [personal selection Valvoline 20w-50w synthetic Case][Lucky me on sale at Kragen 3.99.]
Porsche states Mobil one.
- Oil filter Q128/ 996 107 020 53
- Fuel filter 996 110 253 01
- Air filter 996 110 131 04
- Spark plugs Bosch - FR 7 LDC4
- Spark plug cables - none
Good Luck,
Scott
Edited by mrmickeymouse
I don't mind Mobil 1, but Mobil 1 does not have the viscosity I prefer. Valvoline synthetic only because I have racer friend who swears by it; he did some tests on his own and saw Castrol [my favorite] make excessive wear in the valve train.
So I am stuck with two [self imposed] Mobil 1 - wrong viscosity or Valvoline which he uses and likes, and now I like due to only burning 1/2 quart of oil in 5000 miles. Porsche states it should be higher, oh well.
I am happy, it's quick and I don't hear any valve rattle. I love 20-50W, works well for me.
I can only tell you what works for me and my cars, average miles are 150,000 plus.
My Boxster is my baby with 137,000. There is no protection at 0W [in my opinion] If someone can tell me why I should run Ow [baby oil] in my car please enlighten me.
Please don't say Porsche said so, some empirical testing will suffice.
Scott
0W-40 improves gas mileage (lower friction). Also if you live and drive in cold climates (below freezing) then thinner oils (10w) would probably be necessary.
Otherwise if you live in a warm climate and you do not care about maximizing fuel efficiency then the added protection of heavier oils (15w, 20w) is worthwhile.
It's funny you should talk about gas mileage, I average 20-22 around town [some on freeway/ some off]. 90% lead footed, sorry I love the speed and power of my Boxster.
What's cheaper a few cents in gas mileage or a new motor sooner.
BTW - Is my mileage different then most people?
Scott
So I guess after a TrafficPro installation this car is a mile away from One Million?
without counting this Million mile car...
No. 1 MrMickeymouse with 137k
No. 2 Scherb with 86k
No. 3 ..........
Scott
You get better mileage than Sonja (02 S). On tollway trips and cruise control I get 20-22. Around town, 16-18 is common. I usually accelerate at 70%-100% throttle leaving a stoplight. In my experience, higher speeds do not significantly impact mileage as I have gotten 21MPG top down with 50% of the tank driven in the 130-150MPH range :D Top up adds a couple of miles per gallon when 5th and 6th gear cruising.
I went to the dealer to get my oil filter and I got the following:
996-107-225-53 Oil filter inser...
996-123-106-30 alum seal ring.... They did not give me the Oil filter Q128/ 996 107 020 53
Can anyone confirm this is ok?
Car: Box 2.5L 1997
You have the correct parts except the crush ring for the drain plug starts with 900, not 996.
Should also be an O-ring in the filter box for the cannister.
