996 carbon door sills
3M makes a adhesive remover wheel that goes on a rotary tool or drill. I have one and it works quite well. saves a lot on the elbow grease. B)
Thanks guys,
I'm actually looking for something that would soften the glue, so that I can easily scrape it off. Most of it came off easy in one piece, but there is still some left.
Kristian
+1 on the 3M adhesive remover. You can get it at most hardware stores. Wear a mask and use in a well ventilated area. The stuff is quite nasty B)
I went to Autozone and got something similar, since they did not have it.
I will let you know how it worked.
Kristian
