Cayenne S cooling fan stays on
04 Cayenne S, engine was stone cold, but engine cooling fan stayed on after ignitionn switched off, stayed on long enough to drain the battery, pulled fuse 1 and it went off
What brings the fan on/off? Is it just the senors located in the "distrubtor coling tube"? 99660641000
TIA
You will need a PIWIS diagnostic or similar tool to read out the fault codes which are stored in the control box memory, its possible to check the engine temp. directly from the DME etc.. Air conditioning system problem and faulty control box are also possible, without the codes its guessing.
I believe there was a updated part for the coolant temp sensor to correct this issue.
Part number 99660641000 seems to be the original number and still valid, can you expand on your comment?
TIA
Sorry I might be getting confused with the Touareg. There was a updated temp sensor to resolve this issue on the V8's.
