Can some one share a DIY on how to replace a fuel filter on 996tt , i highly appreciate it.
MY please...if it is 02+, the fuel filter is part of the fuel pump and is not normally changed.
There is a fuel filter on the left side over the engine. Part# 996 110 253 52 about $40.00. Located just beside the coolant reservoir. There is a way to lower the engine about 2 to 4 inches to give you more space. ......
post-29683-1262128714_thumb.png post-29683-1262128728_thumb.png post-29683-1262128738_thumb.png post-29683-1262128748_thumb.png post-29683-1262128964_thumb.png
Right there Wross...
jd..read this link clearly states fuel filters are only for pre-02 cars...so I do see the PN in PET,and the maintenance schedule says to replace at 60K...so I guess I'm wrong...
Edited by wross996TT
Thanks to everyone that responded to my querie. I learned already how to do it. but last time when i tried to lossen the 18mm bolt ,i was unsuccessful.any clue?
Maybe I should use impact torque wrench?
The only thing I can tell you, I had to used 1/2 inch drive ratchet with a 3 feet pipe over the ratchet handle and it work! The torque of these two nuts should be 85 foot pound.....
The build in the tank fuel filters (MY 02>) return less fuel system covers Carrera/Boxster M96 engines. Turbo's still had the conventional system.
Ah, that explains it...thanks!
May be it is a dumb question; what is MY (like MY01 or MY02) stands for? :(
Nghia
Nghia
Model Year...better for identifying the car specs as the purchase year could be different.
Nghia
Got it. Thanks!
  • 4 months later...
Can anyone give me some tips re getting the holder off the expansion tank. I can just about get my finger tips to the plastic clip underneath the filter. I push it up towards the filter but it doesn't seem to want to come free.
Is there an easier way ?
