996 manual transmission faults
Hi.
I have decided to buy a Porsche. I've landed on a 911 996 c4s 2002 or 2003 model. I have found one i prefer, only negative is that it has manual transmission, I was actually looking for one with automatic transmission. I've heard it's different faults with the manual transmission. Is this correct?
Thanks in advance.
Regards.
Some early 996 models have issues with second gear. After some wear it will develop a tendency to pop-out of gear. In my opinion, this excessive wear/damage is generally caused by drivers shifting into second at speeds below 20 mph. Other than that, as far as I know the manual transmissions will last forever (not including the clutch, of course, which is a part designed to wear out). I have 125,000 miles on mine with no issues.
I've enjoyed my 2003 C4S every day I've had it. (Except when the alternator went out and had to be replaced along with a new battery after the car sat for a few weeks without a trickle charger on the battery.) (and every now and then the radio electronics lock-up, but that goes away with either a restart or cycling a cd into the head unit.) (there are some "mysterious Porsche issues" out there, but all are pretty much discussed somewhere in this great forum.) I couldn't pass up the 6speed when I got my car, and I think this forum notes more repair issues with the tiptronic than the manual trans. I was actually looking for a tip, but realized I had another stick left in me. If I lived in the City, or had a heavy b2b commute everyday, I probably have gone for the tiptronic. but for mountain road driving where I live the stick is great fun. cant go wrong with the C4S either way, imho. good luck.
