just purchased a '99 C2 and have addressed several of the "common" issues, BUT
VIN# WP0AA2990XS620263
The fuel gauge drops dramatically for the first 1/4 - 1/2 tank - then levels out.
ex: drive at moderate highway speed @78 MPH
25 miles=1/8 tank used (200 miles per tank)
65 miles=1/4 tank used (260 miles per tank)
115 miles=3/8 tank used (306 miles per tanK)
I am getting approximately 23-24 mpg on the highway over the course of an entire tank. (375-400 miles)
Is there a fix? And is it covered under the
"Recall 00V109000 - Incorrect Fuel Level Displayed"
The recall was for C4's only. They have a much different gas tank because of the 4WD.
Your problem sounds like a sticky float/sender. I would try some Techron or other fuel system cleaner first. If you live in a cold climate you could have moisture (water) in the tank so a gas dryer might be appropriate also.
I don't know how you get that kind of mileage; my '04 C4S cab gets only about 220 miles per tankful, averaging 16.5 mpg at best. I know the C4S tank hold a little less gas than the regular 996, but if I were you I wouldn't worry too much about the interim displays, as long as you know how much fuel is left.
Sounds alright to me. My 996 C2 does the same. Gas mileage is a little less than I get. BEFORE my supercharger, I got 27 MPH average on the highway (consistantly over a 3500 mile trip at speeds averaging 85 mph). Around town I got above 22. I will be making that same trip in a few weeks with the supercharged engine and we will have to see what difference the extra boost will make in gas mileage.
  • 4 years later...
Loren:
Where can I get Techtron and how much to put in the tank, also what gas dryer you recommend? Although I live in Miami think that the change in temperature, very high humidity here, and in what we floridians consider winter my cause a bit of water in the tank.
I have a similar problem with MY99 Coupe, C2, 6 speed standard. Won't show 100% full, after filling up it shows about 1/16 short of 4/4, then the gauge drops very fast during the 1st 30 miles after fillup, stays in 1/2 tank for a long while. I'm getting aprox 220 miles per full tank in the city. Have never let it shows low gas alarm.
Loren:
You can get Techron at Costco, Walmart, or many auto parts houses. And, of course you can buy it at Chevron gas stations.
