Hi my friends boxster acts up when the engine reaches the normal temp. it dies after that. when he tries to crank it it doesnt wana start. he has to wait for it to be cold again and then after that its ok again. can this be the same as the problem on mercedes Crank position sensor? thanks
Yes, the crank position sensor and the system relays are the first suspects IMHO, their values are highly dependent on temperature, engine temp. and heat generated by system power consumers as well.
  • 2 months later...
