I have two Porsches a 1999 C4 Cab and a 2006 Carrera. I love the C4 Cab the BEST and just started to fix some small things like headlights, and cabin Air filter myself. I changed the cabin Airfilter in the front of the car however did not have the cap on and started the car. It made a TERRIABLE Warbling grumbling noise for 30 seconds before I could shut it down and determine that I left the cap off the cabin Air filter. Since I have done that the car has used a Quart of Mobile 1 synthe in only 1100 Miles? Could these be related?
Sincerly,
Soon to be X Handyman:D
One last note regarding the above topic. I do not drive the C4 hard at all.
THX
Are you referring to the top of the cabin filter housing or to the oil filler cap? If the oil cap is making a sucking noise than you might have a failed oil separator.
Edited by dr914jr
My 996 C4 cab 2003 uses a similar amount of Oil, quart per 1,000 miles. Would love to hear more on this subject. I did not have any cap issues.
One quart in 1000 miles is considered within normal limits by Porsche.
Thanks - do you consider it within normal limits?
Yes, I know Turbo owners that use 1 quart ever 600 miles. Some of these cars use some oil and some don't.
I would be more concerned with any abrupt change in usage - double the amount used or oil level all of sudden too high are signs of problems.
