986 Air Oil Separator Failures
Is there any way to simply bypass/disable the AOS? I can't help but think one could simply disconnect & plug the intake manifold hose from the AOS, and leave the AOS output open to vent crankcase gasses... and it would be fine.
Edited by grover
"If the car is running rough, then removing this tube and blocking off both ends should disable the system and restore previous performance. This is not a long-term fix, but instead a short-term diagnosis step to use before you replace the air-oil separator."
http://www.pelicanparts.com/techarticles/Boxster_Tech/09-ENGINE-Air_Oil_Separator/09-ENGINE-Air_Oil_Separator.htm
