hardtop repair
The hardtop is aluminum - so any good body shop/dent repair that works with fiberglass should be able to repair it.
If the rubber piece is just loose and not damaged it can likely be re-attached with 3M trim adhesive. If the rubber piece is damaged it should be replaced.
Edited by Loren
corrected
Jep i was able to bend it back with a smal hammer, just waiting for the hardtop fitting stuff to arrive and then start the challenge ( hope it will fit ! ) .. any tips or advise are welcome! :thankyou:
