On my 2000 Boxster, the glass ovals of the headlights are cracked inside the plastic unit that you remove and brown stains are appearing from the moisture getting cooked from the halogen bulbs. Is it possible to replace just the glass or do I have to buy an entire new headlight assembly?
You may already know this, but changing them will be a snap. Its really easy to take out the whole headlight assembly. I'm sure they are expensive, but like already mentioned, pick some up used.
